Hey i have a weird one my dashboard will light up but none of the gauges will display unless the bike is in gear with the clutch held in
Is there a sensor or relay that could be causing this issue?
edit i unplugged the harness to the clutch lever and the gauges would stay on so long as the bike was in gear. but would turn off if i pulled in the brake. i also recently changed the switches and cover on the key switch and adjusted the clutch cable could this be part of my issue?
Dash gauges will not display
- sammyfranziska
- 1
- Current bike(s): 1984 voyager zn1300
- Has liked: 239 times
- Been liked: 623 times
Re: Dash gauges will not display
I don't think the silver bullet you seek actually exists. I would start by: 1) doing a careful search here (many posts about electrical gremlins); and 2) systematically cleaning all electrical connections you come upon (starting with the clutch switch).
That is, I suspect that you'll need a silver shotgun blast.
- Me Again
- Been liked: 271 times
I've had a similar problem.
I believe it is the glass fuse on the left side (black box).
More than likely just making a poor connection
