Neurtal and Overdrive lights go out
gsmorgansen
Post by gsmorgansen »
The cruise control on my '87 XII quit. At the same time, the neutral and OD lights quit. Reading a host of forum info on this situation led me to believe that the neutral/OD switch needed to be replaced or there was a broken wire somewhere. Wanting to avoid changing out the switch if possible (it's down by the oil site glass and way behind a bunch of stuff and will get oil on the ground when you take it out...fun stuff huh) I e-mailed Carl Leo for sage advice. He said that most often the wire harness connector comes loose for that section of the electrics and take a look first, seeing as how it is right under the fake tank and a whole lot easier to check and fix than the switch. That was it! Five minutes to everything working! Thanks Leo!!!
Greg Morgansen
Greg in Clackamas, Oregon
Charlie from Illinois
Re: Neurtal and Overdrive lights go out
Isn't is great to have people like Carl around and sites like this one? I have no idea how much money I have saved by the knowledge of others on my 03. :clap: :clap:
