Adding electrical gadgets
I know this exists, but I don't know what it's called. I am looking for basically a bank of connectors that I can wire to the battery, so I don't have to wire the accessories directly to the battery.
Any help as to product name and installation procedures appreciated.
Bill
Bill
- Been liked: 134 times
Re: Adding electrical gadgets
abb. TB strip. stands for Terminal Block. Comes in a variety of Number of conections and can be of the insulted type or open type. Can be adhered to your ingition module and you will have enough distance to run your fuse link to the battery B+ and then to whatever device your conecting to the TB. Or if some of your electronic have a pre/fused input lead you can also have the strip wired in off a main fuse lead. Or power the TB off a power/relay that is powered from the ingnition You can Google the items and may be able to purchace online if the vendor doesn't have a min order. Chances are you will find a link to purchace all the items and hardware you need at one vendor. Hope this helps shed some light on this. Gene
Heres a little wiring a relay help file The Power On switch can be omitted and conected to the ing.
- David (N. Alabama)
- Ohio Mike
Bill,
You should be able to find a fused terminal block at a local auto parts store like Advance, Auto Zone, etc. While you are there, I would suggest picking up a fairly heavy wire with a fuse holder built right in to connect from the battery to the fuse block. The fuse in this feed line would need to be large enough to carry the max load you would ever expect to see from all the accessories you have connect to the fuse block or a little less than the max current capacity of the feed wire or fuse block, whichever is less. I have a 30 amp fuse in the feed line since my dual Stebel air horns can draw 20 amps or a little more. Don't forget to add a spare fuse for the feed line to your stash of spare fuses for the block.
Ohio Mike
Ohio Mike
Mike in Celina
- DaveMac
- Current bike(s): 86 voyager
87 voyager
99 BMW K1200LT (sold but not forgotten) - Location: Clinton. MA.
- Has liked: 3 times
I just went to Ebay and got a fuse block. Here is a pic of mine.
BMW K1200 LT 1999 (sold)
kawasaki VOYAGER XII 1987
Kawasaki VOYAGER XII 1986
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Try Radio Shack Bill.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
01 XII-sold
07 Vulcan Nomad
- Chris near Kansas City
