Just wondering if anyone has built their own or reinforced the stock CB antenna mount.
Being a ham radio operator, I am more into function than asthetics so I put a 'Firestick' brand antenna on the stock mount. Antenna works like gangbusters but the stock mount broke in less than a full season of riding. Will post a picture when I get home this afternoon.
Toying with the idea of an aluminum machined part that will slip over the existing antenna end of the mount and securing it with set screws or a pin but have not attempted anything yet. Any solutions or suggestions appreciated.
Thanks,
Ohio Mike / W8DN
Homebrew or Reinforced CB Antenna Mount ??
- vxiirider
- Tourer
- Has liked: 96 times
- Been liked: 32 times
Re: Homebrew or Reinforced CB Antenna Mount ??
I had a friend of mine make me a CB antenna mount out of 1/4" steel rod and small pieces of steel plate. I made a reverse copy of the radio antenna mount for a pattern and he welded it up for me and I painted it black. Has worked well for over 10,000 miles.
John Ramsay
Charlotte, Michigan
'02 GL 1800 Goldwing Trike
Charlotte, Michigan
- Ohio Mike
John,
Are you running the stock antenna or something heavier?
Ohio Mike
Ohio Mike
Mike in Celina
- Current bike(s): 1990 Voyager
Any pics coming soon ? I would like to see your dilemma.
- pasanby
- Current bike(s): Kawasaki ZG1200
Yamaha XJ 600 - Has liked: 0
Hi Mike , I set the SWR on my stock ant. . works really well . After experimenting with several different mike's , with no luck I might add , I installed a kl 203 and that did the trick , seems these radio's are low power and are a great match for the 203 . Or at least mine turned out that way .
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
Mark Twain
- vxiirider
- Tourer
I am running a whip antenna that is about 6" shorter than the stock Am/FM antenna. I cut the stock antenna off to match the length of the CB antenna. I use a cobra hand held mounted on a bracket that I got from Neil , our Air Rider member , and a push to talk switch that I got from him also and a hook up that works through my head set. The only draw back is that you cannot listen to the radio through your head set while you are hooked to the CB. Since I never listen to the radio anyway it presents no problem for me and I only use the CB for group rides.
John Ramsay
Charlotte, Michigan
Charlotte, Michigan
