INTERCOM CABLES
- Current bike(s): 2001 kawasaki voyager 1200
INTERCOM CABLES
Installed my intercom wires yesterday. 2 questions...
- should i grease and tape the connections so they don't come apart and stay sealed
- where is the best place to fasten the plugs to the headsets
- suzib6sw
- Tourer
Re: INTERCOM CABLES
Its best not to put anything inside the headset cables sockets.. It can cause a squeal that can be hard to get rid of. The sockets and plugs have those rubber surrounds on them and shouldnt pull apart in normal use.
Cheers..
Pete
Cheers..
Pete
Pete
1986 Voyager XII
1986 Voyager XII
- Has liked: 87 times
- Been liked: 149 times
Re: INTERCOM CABLES
To each otherleghorn1956 wrote:Thanks Pete, but where should i fasten the ends.
Re: INTERCOM CABLES
My wires came in two pieces. The Y cord and a longer wire for the passenger. The ends were the headsets hook up has a rubber boot. But the connection between the Y and extension pieces is not protected. That is why the tape question came into play. The end plug location is also important to me. Thank again guys.... and gals.
- suzib6sw
- Tourer
Re: INTERCOM CABLES
Understood...
Originally, the groundset cables from J&M came with rubber "clips" that had sticky pads to mount onto the dashboard or trunk..
These, however, are a tad more classy
Make sure the cables hang so no water can enter the plugs..
http://www.ebay.com/itm/Chrome-Cord-Cli ... 100wt_1163
Pete
1986 Voyager XII
1986 Voyager XII
- Nathan (South Carolina)
Re: INTERCOM CABLES
My extension for the passenger runs along the frame and is plugged near the driver's seat under the false tank. It has been that way for 11 years with no problems. I had to replace the Y-cord because the driver's plug only has one channel now. It appears to have a loose connection inside because the sound comes and goes on the left channel.
Lone Eagle
2001 Kawasaki Voyager XII
- suzib6sw
- Tourer
Re: INTERCOM CABLES
Nathan.. send me the cord .. i may be able to fix it..
Pete
Pete
Pete
1986 Voyager XII
1986 Voyager XII
Re: INTERCOM CABLES
Pete, these also have little rubber cups with sticky tape to fasten to the bike and hold the cable ends in place when they are not being used. Yahoo... must be the high end ones... Waiting for some steady weather here in southern Ontario.
