Fairing Buzz/Rattle
EVAHank
2010 Honda NT700V
Fairing Buzz/Rattle
Post by EVAHank »
I have a 2010 VV 1700 with about 7800 miles on it. I recently completed a 2400-mile cross-country trip, and I have noticed that my fairing is rattling a lot, and seems to 'buzz' at certain speeds/rpms.
I'm also concerned about the windshield mount, at higher speeds it seems to place a lot of stress on the pod containing the radio and gauges. Has anyone else had this problem, and is there a fix for it?
Any information/observations would be appreciated! Thanks.
Ride Safe & Sane;
Hank & 'the Grey Ladies' :LAngel
RodWestphal
Current bike(s): 209 VV1700
2008 Concours14
Re: Fairing Buzz/Rattle
Post by RodWestphal »
When I had mine, I had to tighten the screws on top of the dash a couple times. I believe there are two of them. That quieted everything down. No problems with the windshield mount that I noticed. Also some have had a vibration of the nacelle around the ignition switch. When you notice the buzz, try pressing on that nacelle or the top of the dash to see if that quiets things down.
RR
Have Motorcycle Will Travel
2009 VV1700
2008 Concours14
David (N. Alabama)
2014 Triumph Trophy SE
Post by David (N. Alabama) »
Hey Hank. When I took my fairing apart to service the steering head bearings, I noticed that the gauge cluster fasteners were a little loose. Also the plastic chrome rings around the gauges vibrated a little so I glued them. The windshield and inner and outer fairing are fastened to an internal frame so the windshield should not be putting stress on the inner fairing.
Champion Trike
Been liked: 4 times
Post by hank43 »
EVAHank wrote:I have a 2010 VV 1700 with about 7800 miles on it. I recently completed a 2400-mile cross-country trip, and I have noticed that my fairing is rattling a lot, and seems to 'buzz' at certain speeds/rpms.
Ride Safe & Sane;
Hey Hank;
This is the other Hank. I too, have recently developed a buzz on my '09 VV1700. Tell me, does it go away when you pull in the clutch? Mine does. (At first, I thought it was the wife, but turning off the intercom did not make the buzz go away). Seems to only present itself when the bike is under load. This started during our trek across the US to the Logan AVA rally.
hank
Discovery
Current bike(s): 2013 Kawasaki Voyager 1700
Post by Discovery »
I know this I an old post but I just saw it today. Almost 90% of the time that rattle is the chrome tank bib around the filler cap. Mine was starting when I hit around 2700 RPM.s. I was sure it was coming from the fairing but noooo. Take it off and put some sticky back insulation tape under the length of the bib. Noise gone! I have not experienced the lose gauge rings in the dash but I know that can cause the same problem. :thmup:
Pathfinder117
Champion Trike
Been liked: 4 times
Post by hank43 »
Actually, in my case, it was that chromed plastic cover on the bottom of the top box, both sides rattle, haven't had the time to take seat off and tighten the screws.
hank
coolaid2201
Current bike(s): 2010 kawasaki voyager 1700
Post by coolaid2201 »
I had the same problem on my 2010 1700 voyager , i found it was the chrome gas tank piece ,, the front of it is so thin it vibrates ,, i took mine off and coated the back of it with a layer of potting to stiffen it up,, no more noise.
1st one
Current bike(s): 2009 Kawasaki Vulcan Voyager
Post by 1st one »
This is more likely your problem as this is my problem on my 2009 Voyager
Then your not riding enough
2009 Voyager
1st One
boscoe
Current bike(s): 2011 Voyager
Post by boscoe »
Mine rattles from the right glove box area of the fairing. if I press on the plastic around the lid, or on the inside of the fairing by the triple tree, the noise goes away. I haven't yet got around to looking at it- I did check the screws for the glove box and the speaker- they were tight.
2011 Voyager 1700
Ebony/Pearl Meteor Gray
Bridgestone Exedra Max tires in stock sizes
Kuryakyn Longhorn Offset Dually Highway Pegs
DEI Titanium exhaust header wrap
Polk Audio db521 speakers
Mobil 1 10W-40
NSASarge
Been liked: 6 times
Post by NSASarge »
I found the source of my "BUZZ". It's the lower shutter. I put a 2-inch long piece of 3/4 by 3/4-inch heavy duty sticky-back foam under the shutter just in front of the pivot mount. This will push up on the shutter in open or closed positions :thmup: and keep it from BUZZING.
Ride Safe
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
AAA: 620111405125201
Patriot Guard Rider
Retired US Army MI
Retired Thomas Built Bus
Retired
