Buzz or rattle after long trip
Champion Trike
Been liked: 4 times
Post by hank43 »
Only happens when under load, pull clutch in, buzz goes away. Thought at first it was the ignition nacelle, but that's not it...now wife swears she hears it from underneath the back, in the area of the drive belt, but that does not make sense, because when I pull clutch in, bike is still rolling, but noise goes away.
Any one have this problem?
debron
Re: Buzz or rattle after long trip
Post by debron »
Just a thought, when you pull in the clutch, the belt, though the bike is still rolling, is no longer under "drive tension." That is, it's free rolling, not being pulled under tension from the engine.
David (N. Alabama)
2014 Triumph Trophy SE
Post by David (N. Alabama) »
Buzzes are hard to find. I had the chrome rings around the instruments buzz some. Also, if there is anything loose in the glove boxes or saddlebags.
Kevin B in Illinois
1990 Kawasaki Voyager XII
2009 Kawasaki Vulcan Voyager
1969 Kawasaki Sidewinder 250
1965 Kawasaki F2TR 175
2006 Suzuki DL1000
Post by Kevin B in Illinois »
The belts on Vtwin engines tend to be sometimes a little noisy sounding if they are a little out of alignment. I know on the Vulcan Voyager 1700 it has a slightly different belt noise sound to it , than the HD Ultra belt sound or the Road Star 1700 belt sound that I have heard of the bikes I've owned. I would check alignment and also see if there is anything in the guard area of the belt drive, Hard to figure it out without it being in front of me. Just the thoughts on this Sunday afternoon.
Kevin Braddy
IPVMC
President
NSASarge
Been liked: 6 times
Post by NSASarge »
I found the source of my "BUZZ". It's the lower shutter. I put a 2-inch long piece of 3/4 by 3/4-inch heavy duty sticky-back foam under the shutter just in front of the pivot mount. This will push up on the shutter in open or closed positions :thmup: and keep it from BUZZING.
Ride Safe
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
AAA: 620111405125201
Patriot Guard Rider
Retired US Army MI
Retired Thomas Built Bus
Retired
