Cruise control question
- gery
Hello
Gentlemen, I have a question - what could be the reason that I can not Switch on cruise control.
Cruise control indicator is lit (ON), and I can not set the speed (SET indicator is not lit) ?
gery
gery
- the2knights
- Board Member
- 12
- Has liked: 32 times
- Been liked: 8 times
Re: Cruise control question
Could be a couple of different things, but for myself I have found it to be a stuck switch on either the front or rear brake. The cruise will not set if the brake lights are on, plus there is a safety switch that operates off the brakes as well. Also, I am assuming your speedometer is working, but if not it will not set and automatic volume control will fail to work on audio as well.
- doug of so fla
Gery: there are small micro switches at the clutch lever & the front brake lever, and rear brake pedal. & throttle cables in by the carbs. The most common problem is the brake lever, when you pull in & out the lever you should here 2 clicks this switch goes bad more than others & also if your levers have to much up & down play in them it will not make contact with the buttons on the switches. Look under the levers and you will see them. If you do not have stock levers this could be the problem also. Also check to see if the wires to them are making good contact. The rear pedal has the switch under the plastic cover at the rear of the rear brake pedal. It is when you release the pedal and levers that the switches let the cruise stay on. Also remember that the cruise will not set if you are going under 40miles per hour or over 85mph.. and it will not "set" if it is not in 5th gear.!! There is also a adjustment at the control unit under the front faring that may be way out of adjustment and not let it set. & if speedometer is not working it will not set. The switch by the carbs usually is not the one that has a problem but it may be bad also. To check the brake switch you can connect the two wires to bypass it. You have to find which two wires are for brake light , then the other two are for the cruise. Hope this helps, Let us know what you find and we can go from there..
- gery
Ok, thanks guys for any suggestions. I'll check.
- Has liked: 88 times
- Been liked: 153 times
Gery, here is a link to a YouTube video that Chris near Kansas City made concerning cruise control.
This may be beneficial/helpful to you.
http://www.youtube.com/watch?v=KHhJmGpqeYQ
- joerod777
- Current bike(s): 2003 Voyager XII
I experienced a similar issue and discovered that you need to be in 5th gear for CC to work. I also found that if your speedo cable is broken the CC will not work
JoeRod
- gery
My speedo cable works fine. I tried to turn on the CC in fifth gear at 50 miles and nothing. I measured the micro-switch on which you wrote, and I think that the problem lies precisely in it. At the micro switch contacts ohmmeter shows the circuit is closed in the off position. Well, unless it has to be?
Again, sorry for my english but I support the online translator.
gery greet
gery greet
- 12
- Current bike(s): 2002 voyager (sold)
1999 voyager - Location: Wichita Falls
That just happened to me this past weekend and sure enough it would not set because of the bike not being in 5th gear. Hopefully it's as easy as that.
- gery
I checked all of what you wrote. Still Not Working - any ideas.
gery
gery
- Gator Mike
2002 Honda 750 ACE
Gery did you check the micro switch on the carburetor rack? This one does not go bad nearly as much as the brake and clutch, however, it is actually bad on my bike and I have it disconnected. Just a thought. Hope you find it.........Gator Mike
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
- gery
Ok, I checked all the switches - are all ok - carburetor, front brake, the brake pedal and clutch. Where should I look next?
gery
gery
- Has liked: 890 times
- Been liked: 314 times
Do you have a service manual? It has a pretty good diagnostic test page,which is what I had to use to get mine going.After I got it going,and adjusted the cable, it has worked perfectly.
- suzib6sw
- Tourer
There are TWO switches by the rear brake pedal.. One for the light, the other for the cruise.. Make sure you are testing the correct one :-)
It could be a broken cable of course..
Service Manual Supplement Section 15-8 details the switches operation and how to test etc..
Thanks
Thanks
Pete
1986 Voyager XII
1986 Voyager XII
- Current bike(s): 1989 Voyager XII
- Been liked: 16 times
- gery
No, should it?
gery
gery
Yes.
This is the problem I had. Down by the sight glass is the neutral/OD switch. It has two wires running to it. I had to clip the black wire before the swtch and run it to the frame to ground it. This causes the OD light to be on all the time. It also restored the cruise.
I don't mind the OD light being on all the time. If you wouldn't like that, this isn't the fix for you. The alternative presented to me was considerably more time consuming and $$$$$.
- gery
Ok, I will try to do it.
gery
gery
- Bill O
2003 1200 Voyager
- Been liked: 6 times
sheiserman wrote:Yes.
On my '94, I had a local shop do some work for me and after that my cruise wouldn't work because the tranny would never show 5th gear (OD light). Turned out they screwed up the internal contacts for the OD switch. I did the same (grounding the wire) and the cruise worked again. But!, I took it one further, I had an available switch on my sets of Markland accessory handlebar switches so I routed that wire back up to the handlebar switch and the other side of the switch I then ran to ground. That way I could disable the cruise and OD light. Secondary benefit..... I could now run cruise in any gear, as long as my speed was over the minimum of 35-40 mph.
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
1994 Voyager
2003 Voyager
I haven't even thought of running the wire through a switch. That constitutes a good idea.
Thanks, Bill.
Thanks, Bill.
- gery
And it works.
Sheiserman you were right. Thanks for your help.
gery greet
gery greet
