Cooling system clean-out?
Own something other than a Voyager? This forum allows you to more easily find non-Voyager articles.
trikebldr
'82 Kawasaki KZ1100D Spectre
'79 Vetter Terraplane sidecar
'85 Kawasaki Voyager 1300
Post by trikebldr »
Has anybody ever tried using a high concentration of Lime-Away and water in the cooling system to clean it out? I have used it mixed 50/50 in a radiator only before, and it does a great job of getting out all that calcium buildup that clogs up the tubes. I just let it sit all night, then did a power flush. Looked like new inside, with no leaks.
My concern in our engines (at least on the ZN1300 engines) is that little mechanical seal between the water pump and the crankcase. It is partially ceramic, and LimeAway will eat some softer ceramics.
Return to “All Other Brands General Forum”
