Minimum voltage
Muleears
Minimum voltage
Post by Muleears »
I just added a pair of electric gloves (about 20 watts) to my bike, I also have a set of LED driving lights (52 watts, I believe). What voltage should my bike be able to maintain? I have a digital volt meter, I want to make sure I'm not overloading my charging system.
Cal
'02 Voyager XII 22K miles
Hampton Roads, VA
Re: Minimum voltage
Muleears wrote:I just added a pair of electric gloves (about 20 watts) to my bike, I also have a set of LED driving lights (52 watts, I believe). What voltage should my bike be able to maintain? I have a digital volt meter, I want to make sure I'm not overloading my charging system.
I would be concerned with anything less than 13.3 running down the road. I can with the bike at idle ( @ 800rpm ), radio, garmin gps, and led running lights hold a 12.9 ~13.3 volt reading depending on the state of the battery being up to 100%.
voyager55
Current bike(s): 2003 1200
Re: Minimum voltage
Post by voyager55 »
When worrying about electrical load, go by the number of amps you're drawing. Not watts. Our bikes have a 35 amp alternator.
The little amount of power you're using isn't a concern
Muleears
Re: Minimum voltage
Post by Muleears »
voyager55 wrote:When worrying about electrical load, go by the number of amps you're drawing. Not watts. Our bikes have a 35 amp alternator.
I guess I'm only drawing about 6 amps with my accessories, I don't know what the bike itself draws as a baseline though. I should have mentioned my turns/brake and running lights are all LEDs. I'll keep an eye on my running voltage too and see if it begins to drop I'll look into it further. Thanks for the advice.
Cal
Hampton Roads, VA
Has liked: 115 times
Re: Minimum voltage
For the purpose of calculations, watts divided by voltage gives amperage, and conversely, amperage times voltage gives watts.
ghostler
Has liked: 3 times
Been liked: 10 times
Re: Minimum voltage
Post by ghostler »
I'm currently running heated grips and tow a conventionally incandescent lit Harbor Freight trailer without problems. I'd think your load is okay. Main thing is no amp draw from your accessories when key is off.
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
