Forktube plug removal
ffltstn
Current bike(s): '95 Voyager
'82 KZ1000J
Post by ffltstn »
Bike's way over due for a fork oil change. Bike is on center stand and blocks (my jack has a slow leak). Have drained the oil and removed the snap ring.
Is there a trick to getting the plug to come out of the tube?
I have tried lifting the front wheel with a board under it but am afraid of rocking the bike off the stand.
Should I let the bike down on the jack? Replace drain screws and add air?
Thanks,
Ken
Ken In Orlando Fl.
'95 Voyager
'82 KZ1000J
voyager55
Current bike(s): 2003 1200
Re: Forktube plug removal
Post by voyager55 »
http://www.abbikeboard.com/jeff/spring/spring.html" onclick="window.open(this.href);return false;
You need to push the plug down and remove the snap ring holding it in.
The link I posted shows it well
Has liked: 115 times
Once the inner circlip has been removed, the o-ring of the cap sometimes causes the result you are dealing with. Try rapidly tapping on the cap with a brass/steel drift and a small hammer. Think of it as imitating a riveting hammer type of motion/action with the loosely held and lightly tapped drift. No need for great whacks, just steady, moderate, tapping, and the force of the spring should pop the cap out.
I know it sounds crazy but it has worked for me.
doug of so fla
Current bike(s): 07 gold wing
Post by doug of so fla »
Did your loosen the upper fork clamp pinch bolt. Sometimes someone may have tightened the pinch bolt to tight and it will hold the plug from popping out.
ffltstn
'82 KZ1000J
Post by ffltstn »
As I posted the snap ring is out and the other post does not show the plug coming out. I tapped it once I'll give it a couple more tries and then loosen the bolts.
Thanks.
UPDATE, A few taps and they popped right out.
There are progressive springs in there already!
Do I need to worry about replacing the o-ring on the plug?
Ken In Orlando Fl.
'95 Voyager
'82 KZ1000J
voyager55
Post by voyager55 »
No, unless you know it's damaged
ffltstn wrote:As I posted the snap ring is out and the other post does not show the plug coming out. I tapped it once I'll give it a couple more tries and then loosen the bolts.
Thanks.
jek7galo
Current bike(s): Kawasaki ZX-12R - 2000
Kawasaki Voyager XII - 1995
Post by jek7galo »
Whats the capacity of fork oil in each ? :hmm: :thk:
thanks
Kawasaki Ninja ZX-12R - 2000
voyager55
Post by voyager55 »
Read the link I posted.
jek7galo wrote:Whats the capacity of fork oil in each ? :hmm: :thk:
thanks
jek7galo
Post by jek7galo »
Ok, but I dont know, if is 391 mL in each fork or total of two forks ?
Missing only know that to assembly.
Thanks
each fork
jek7galo
Post by jek7galo »
triton28 wrote:each fork
:thmup: :thmup: :thmup:
With the forks off use the 160mm from top.
With this method you will have both forks exactly the same.
I use a hand vacuum pump with a steel tube and a stop on it at 160mm' slightly over fill then suck the oil down until it pulls air.
:thmup:
jek7galo
Post by jek7galo »
thank chevyman :thmup:
