fuel and air filters
krasmu
Been liked: 18 times
Post by krasmu »
I know I've seen this but darned if I can find it. "I'm really computer challenged". Are there conversion numbers for a compatible fuel filter that I may pick up at an Autozone? Is there one for the air filter as well? I'm having trouble finding these two items around my place. Any help would be greatly appreciated. thanks
Kirk Rasmussen
Machesney Park, Illinois
hotrodpappy
Current bike(s): 1999 Kawasaki Voygar
Re: fuel and air filters
Post by hotrodpappy »
krasmu wrote:I know I've seen this but darned if I can find it. "I'm really computer challenged". Are there conversion numbers for a compatible fuel filter that I may pick up at an Autozone? Is there one for the air filter as well? I'm having trouble finding these two items around my place. Any help would be greatly appreciated. thanks
Go to the AVA home page and click on Tech center then at bottom click on dollar for dollar hope this helps
Jim
Got the best cycle money can buy
1999 Voyager XII
I have found that the best bang for the buck is to use the John Deere fuel filter John Deere - Part #AM116304 which fits without any modification and only costs around $6.
kjsett
2009 Suzuki Vstrom DL650
Post by kjsett »
Mr Jensee wrote:I have found that the best bang for the buck is to use the John Deere fuel filter John Deere - Part #AM116304 which fits without any modification and only costs around $6.
That is what I use. Fram, from what i hear, isn't the same quality of filter it used to be. I use the K&N filter for oil (K&N # KN401 $9.99 at Cycle Gear, 06/2014 - includes required o-rings $11 at Amazon(Aug'15)) and the cleanable one for air. I would have to look that one up (from a chevy it think), but I have K&N air filters on my Dodge Cummins, my wife's Vn800a Vulcan and my '03 Voyager. I clean them twice a year unless I go thru an unusually dust event or roads (i try to avoid the dusty dirt roads down here in Arizona). You have to save the plastic frame from the old air filter and then adapt (trim) the Fram or the K&N to fit.
Enjoy
The air filter is for a 1987 Camaro, Rockauto $2.00
Check out these sites
http://www.tinlin.net/motorcycle/parts.html#filters
http://www.rockauto.com/catalog/raframe ... ttype=6192
:thmup:
krasmu
Post by krasmu »
perfect. you guys are great. thanks so much. those are the final two items I needed for my winter maintanence. :woohoo:
Kirk Rasmussen
krasmu
Post by krasmu »
I picked up the air filter for the 87 Camaro but it is to small. Are you guys breaking them apart and inserting the Camaro filter element into the housing of the OEM filter?
Kirk Rasmussen
krasmu wrote:I picked up the air filter for the 87 Camaro but it is to small. Are you guys breaking them apart and inserting the Camaro filter element into the housing of the OEM filter?
you must trim about 1/8 inch off width and length and then you must take the original equipment filter and gut it so you have just the plastic frame.
Then you must insert the Camaro Filter into the frame and silicone it in place.
:thmup:
voyager55
Current bike(s): 2003 1200
Post by voyager55 »
Or just order the OEM filter from Carl.
krasmu
Post by krasmu »
Didn't take long to figure out how to cut things down and make this work. Thank for the replies.
Kirk Rasmussen
