Replacing antennae cable - How to access
svenolie
Has liked: 6 times
Post by svenolie »
Hello,
I need to replace the radio antennae cable. What's the best way to access? How much fairing needs to come off? (Right side).
Thanks in advance.
Re: Replacing antennae cable - How to access
If you are asking where does the antenna plug into the radio there is a Motorola plug coming out of the back of the radio. To access everything easily you will have to remove the upper right faring. Start with the removal of the headlight bracket, headlight. Remove both mirrors, remove the windshield, remove the chrome strip below the windshield. Remove the right lower faring, then remove the upper right faring. You can then remove the dummy tank and trace the coax cable back to the antenna itself.
svenolie
Has liked: 6 times
Post by svenolie »
Mr. Jensee,
Thanks for the response.
I figured it was pretty involved.
When I do this, I will learn a whole lot more about my Voyager. :-O
