Fork Leg Lights - Kawasaki Accessory
- kehnisz
- Current bike(s): 2006 Burgman 650
Does anyone have a set of these lights on their XII. What wattage are the bulbs - total of 4 correct? I am trying to determine how many watts I can run off the 'white headlight cavity female connector' if I connect auxiliary lights to this powersource.
K Ehnisz
Past Vice-President NorCal Voyagers 2012-2013
USCGR (ret)
2006 Suzuki Burgman 650
USCGR (ret)
- suzib6sw
Re: Fork Leg Lights - Kawasaki Accessory
The Black/Yellow White/Yellow Bullet socket connection is protected by and is documented as a 10 amp Acc (Auxilliary) circuit However, if you can use LED's instead, I would rather than 194's (4 Watt each) or 168's (5 watt) or 158's (3 watt).
Make sure the LEDs you get have a good all round and forward illumination.
You could, wire them into the side markers and then do the alternating indicator/side marker mod so that flash in opposition to the main turn signals
Cheers..
Pete
Cheers..
Pete
Pete
- Davew
- Current bike(s): 03 Voyager XII
1976 Kaw. KZ900LTD - Location: Summerville, SC
Check with Carl Leo he may have a set, he had the ones off of my bike which are already equiped with led bulbs (bulb are not 194 peanut bulbs) they are a small bannet base bulb, don't remember the number right now but if you need it PM me and I'll see if I can find the number. When I had the fork leg lights on my bike I tapped into the marker (running) light circuit on the turn signal bulb with no problem.
David Wirtz
Summerville SC.
Past AVA board member
Palmetto Voyagers, AMA,SCRC, ROK
03 Voyager XII & Bushtec Trailer
Summerville SC.
- Kevin B in Illinois
1990 Kawasaki Voyager XII
2009 Kawasaki Vulcan Voyager
1969 Kawasaki Sidewinder 250
1965 Kawasaki F2TR 175
Dave is correct on tapping into the side marker lights without issues. I think Carl had a couple sets of those hanging up in his garage. I have also seen rider's convert the Gold Wing version of the lights which come with three on each side for use on the Voyager XII.
Kevin Braddy
IPVMC President
Past owner of
Current owner of
2009 Voyager 1700
Kevin Braddy
IPVMC President
Past owner of
Current owner of
2009 Voyager 1700
- Dion
- Current bike(s): 2006 Goldwing 1800 1989 Honda Pacific Coast 800
Kevin your missing a few bikes on that list
- kehnisz
Thanks, I have a pair of rectangle H3 lamps mounted on a flat-stock aluminum bar - I was going to relamp them with this LED bulb.
http://www.amazon.com/dp/B006RNY1S6/ref ... nkCode=asn
H3 68-SMD PX26d 12V LED Fog Light or DRL bulbs Xenon White - power draw appears to be 2.5 W each.
Your thoughts???
Your thoughts???
K Ehnisz
USCGR (ret)
USCGR (ret)
