Another newbie noise question 92 Voyager Xii
MNBlue
Current bike(s): 1992 Voyager Vii
Post by MNBlue »
So the weather has turned I've had my new (old 92) voyager out and am hearing a little howl in the back end. At first I thought it was road noise, but I only hear it when I am accelerating or under load. I changed the rear end fluid this spring, and checked it again and it is still a little below the threads.
Do these bikes have some noise from the shaft drive or is there something I need to check into? If I need to look into something any thoughts on where to start?
Thanks from MN!
vxiirider
Tourer
Tourer
Has liked: 93 times
Been liked: 30 times
Re: Another newbie noise question 92 Voyager Xii
Post by vxiirider »
The final drives have square cut gears and some Voyagers howl worse than others. if it's not too bad the solution is to turn the radio up. A few have been so bad that the solution was to replace the final drive with one that has been tested (used) and is known to be quiet. I think that some have re-shimmed the gears but that is way beyond my mechanical ability.
John Ramsay
Charlotte, Michigan
'02 GL 1800 Goldwing Trike
by "howl" do you mean it sounds a little like George Jetson's space car? That's what mine sounds like on the highway.
Sarge1961
Current bike(s): 1992 Kawasaki Voyager XII
Post by Sarge1961 »
I to have a 92 Voyager XII and had the same noise that you're talking about. I changed the fluid I also added some Motorkote to the oil. Now I've been using this product for years now and it works great and the noise is not as bad. You can also use this in the engine with no problems with the wet clutch. They also have a fuel product (Black 16 oz bottle) that works great and you only need 1 oz per 10 gallons compared to 1 oz of seafoam per gallon.
You can find Motorkote at Walmart but the fuel additive you'll need to order from their web site. I've also used this in my car,truck,lawn equipment & tools and guns. Any place or thing that you need lubed this stuff works, check it out.
http://motorkote.com/
For those who like pictures and videos.
http://www.youtube.com/watch?v=gIEZ58wnUyM :thmup:
For Walmart.
http://www.walmart.com/search/search-ng ... nstraint=0
Tom(North Alabama)
Current bike(s): 2002 Voyager II
2002 BMW k1200LTE - sold
Post by Tom(North Alabama) »
Another thing to take a look at is the rear axle bolt, mine was waaay too tight, had to use a 6ft breaker bar to loosen. It helped with the noise, but finally ended up buying another final drive, absolutely quiet now.
This is my 3rd Voyager had an '89 then '98 and now '02, the last one was the only one with the noisy rear, it was so bad ear plugs did not help much.
By the way, never found any of the gear oils or synthetics helped the noise much.
'02 Voyager XII
'08 Concours 14 - sold
'02 BMW K1200LTE
Chris near Kansas City
My '90 was so bad when I got it in '02 with 49,000 miles on it, that I couldn't ride it at 50mph without a helmet on because the whine was so bad.
debron
Post by debron »
In the XII "Tech Center" section (accessible from the AVA homepage) are instructions for adjusting the Balancer Gear Backlash, which may (or may not) reduce the gear noise.
http://www.amervoyassoc.org/XIITipsBody ... 20Backlash.
glich54
2009 Kawasaki KLR 650
1979 Triumph Bonneville 750
1951 Cushman Eagle
Post by glich54 »
Guess I'll have to pick up a final drive on flea bay....pretty bad howl, but only between 65-70mph....have tried the special lube, the axel nut torque, the backlash but the only thing that has worked is to drive 64 or less or 71 or over...
Gary L.
Woodinville, WA
01 Voyager XII
51 Cushman Eagle
debron
Post by debron »
glich54 wrote:Guess I'll have to pick up a final drive on flea bay.....
Did you try Carl Leo?
