1.) I found the part number for the Progressive springs themselves. When I order a fork rebuild kit, I'm still looking for all the normal factory seals, right? There's nothing special or different I need to be looking for in relation to parts?
2.) Should I replace rubber seals around the air tube? Is that part of the rebuild kit?
3.) OR since I'm doing the Progressive springs, should I just do away with the air system altogether? What would be the recommended way to handle that?
4.) Nails mentioned adding a pressure relief valve someplace. Should I seriously be looking into that, and if so, what would the part be?
Many thanks! I think this is the last thing I need to deal with before FINALLY getting this thing back on the road. What a slow project.
