Longevity
grumpy72
99 shadow 1100
93 voyager 1200
Been liked: 15 times
Longevity
Post by grumpy72 »
I owned a 92 parts bike, then an immaculate metallic green not sure what year. Shoulda kept that one. Then briefly a 6 cylinder. Bought for a 100, sold for 400. Now my 2000 model. Once some things are fixed its a keeper. I guestimate with routine upkeep these motors go 100,000 easily. The 10 to 1 compression is worrisome.
Has liked: 87 times
Been liked: 149 times
Re: Longevity
Grumpy72, there are many, I repeat MANY Voyager XII's with 100k, 200k and some with 300k miles.
Basically as long as you keep up on routine maintenance & oil changes these bikes historically will last and continue to provide a wonderful riding experience 😀
cushman eagle (Fri Feb 21, 2025 5:43 pm)
Conrad
89 yamaha venture royale
Has liked: 27 times
Been liked: 61 times
Re: Longevity
Post by Conrad »
That's what I'm hoping for, my '93 only has about 43,000 on it. My biggest worry is discontinued parts, i went through that last winter with radiator hoses etc.
Has liked: 87 times
Re: Longevity
I personally know no less than 3 owners who have joined the 100-thousand mile club. I also know of more who have hit 2k and remember one fellow who was pissed when his Voyager let him down when it only had 315,000+/- miles in it. I laughed like a fool when I read it thinking "these aren't diesel engines, but they must be bullet proof!"
Has liked: 881 times
Been liked: 304 times
Re: Longevity
My '99 has 116,450,and still runs like new,uses no oil and has had no internal engine work :thmup:
I did change the water and fuel pump.I also had the alternator and starter rebuilt,as a prventive measure.I also replaced coolant hoses and O-rings over the 15 years I have had it.
Scott-(Altoona, PA) (Sun Feb 23, 2025 1:39 am)
Has liked: 495 times
Been liked: 444 times
Re: Longevity
Gertrude had 114k miles at the time of the accident and would hold her own against a Concours 1000 which was only slightly faster. 45 mpg, do 120 all day long, used no oil, no leaks, would start right up if you just looked at the starter button. Shame she got totalled - she and I had been through so many adventures - such as frame bolts falling out and replaced by the DSPO with machine screws about six inches long, airbox fire that kronked the original carbs (also during DSPO's ownership but it took me 45k miles to finally replace the carbs and air box), bad wheel bearings that had been diagnosed by a "tech" at the dealership as "fine" - that also took out my forks. Only time she ever leaked anything was on cold nights the coolant pipe o-rings would leak. Every winter I'd tell myself "when it gets warmer I'll fix them" and then when it was warmer they didn't leak and I was too busy riding to fix them. Oh yeah and the Mexican Jumping Saddlebag Lids, let's not forget them. That was cured by Gene Kap adjusting the latches and also I installed tethers. Also kept the lids locked. Only things that actually broke during my 60k miles of ownership was the speedo gear (the stamped metal thingie) wore out, I broke a speedo cable, broke a choke (excuse me, enricher) cable, and the clutch leaf springs went. So whilst I was in there I replaced the clutch pack (a rare item to wear out on these) because all those miles in Philly traffic and stop signs and/or traffic lights every block or two made it about time to replace it.
1971 Com-Pac 16
SJ Retreads, PGR, WWR
