rear valve stem
- Current bike(s): 1996 voyager
rear valve stem
looking for the rear tire valve stem for my 96 are they the same size as the front i can find those but for the rear every body wans 30 dollars
- Has liked: 495 times
- Been liked: 444 times
Re: rear valve stem
They are the same size but different angles. The front has a 45 degree bend to clear the brake discs, the rear 90 to clear the final drive. Some guys run straight valve stems on the front - I have no idea off the top of my head if there's enough room to do the same on the rear.
1971 Com-Pac 16
SJ Retreads, PGR, WWR
1971 Com-Pac 16
- Has liked: 237 times
- Been liked: 622 times
Re: rear valve stem
FWIW, I recommend installing the rear stem backwards, toward the brake rather than the final drive. Easier to reach when the bike is on the side stand.
- Scott-(Altoona, PA) (Sun May 21, 2023 10:22 pm)
