CB
- mountainman
CB
Does anyone know of anything to check as to why a XII cb shows transmit but does not transmit to out?
1982 Suzuki GS750TZ (sold)
1977 Kawasaki KZ650 (sold)
1974 Kawasaki KZ400 (sold)
Re: CB
just from being an old CB'er, the first thing I would check is tranmitter output. I used to use a dummy load, a device you screw into the antenna connector in place of the antenna. Some would light up. That tells you it is transmitting. An SWR meter can also be used but make sure it has a dummy load on it also, if not the transmitter can be damaged. If the unit is transmitting then the problem is the antenna connector, the cable, or the antenna itself. Use a circuit testor to make sure the center conductor of the cable is NOT grounded to the outside of the cable. If it is your cable or antenna needs to be replaced.
- mountainman
Re: CB
Thank you Mr Jensee!
Re: CB
FYI, if you get hold of an SWR meter, the CB should be putting out 3.5 to 5 watts. Later CB's were allowed to transmit the whole 5 watt rating.
- Bruce in OK
- Current bike(s): '01 VXII
'06 Vespa GTS 250
'02 Honda Elite 80
Re: CB
Check with Pete (suzib6sw) for assistance. He'll have an idea. Worst case scenario would be something like the transmit finals being out.
Bruce in OK
- mountainman
Re: CB
ok, thanks a lot! Not sure yet its my cb, but my brothers Harley cb does not carry my transmission. But his cb is saying its receiving a transmission. So i can here him but he can't here me but is receiving a signal per indicator on his unit.
- Bruce in OK
'06 Vespa GTS 250
'02 Honda Elite 80
Re: CB
If it is throwing a signal, but no audio, it might be as simple as swapping out the microphone. Pete can steer you in the right direction. Let us know what you figure out.
Bruce in OK
- mountainman
Re: CB
Have located a swr meter but can't hook up as of yet because there is no connector at bike antenna base. But it has a field strength test on it with the test units own antenna. This test I guess is showing power going out to air waves for as much as I understand about it. Have found a wire harness connector in passenger control bag that was unconnected. Have not been able to try unit since because of the much needed rain here, but hoping on a long shot that might have been it. If anyone understands how to use this tester for my problem I'll be more than happy to listen. Because I don't know beans about how to use it. If I am close to bike and key talk up on cb it pegs meters field strength meter so I'm supposing there is signal output? The instructions with the meter look like the were written by a Physicist and I'm not to that level yet! lol
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Re: CB
I would save myself a lot of headaches and call Pete, 540-391-0884, he is the radio guru, and can walk you through anything.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
01 XII-sold
07 Vulcan Nomad
- Chris near Kansas City
Re: CB
Or the Y-cord.
- suzib6sw
- Tourer
Re: CB
Hmm.. if you can hear yourself in the headset from the mic, then the Y cord is working.. Its possible the signal from the radio to the CB is the issue and I have seen broken wires in the multi pin plugs that connect the CB to the radio.. (The cable from the radio with a brown collar on it).
Before you take anything apart, also try the headset in the passenger socket.. They run in parallel..
Cheers..
Pete
Cheers..
Pete
Pete
1986 Voyager XII
1986 Voyager XII
- mountainman
Re: CB
Thanks Pete, I do here myself in headset and my wife can here me also. Hoping tomorrow night I can test it with the Harley to see if unconnected wires in passenger bag was the culprit.
- k7nutN7nut
- 12
- Current bike(s): 1987 KLR 650
2000 Kawasaki Voyager XII
'00 & '86 Voyager's(parts)
1969 Honda CT90
1985 Honda TRX 125 - Location: Tygh Valley, Or.
Re: CB
You better be sure there's an antenna(resonant at 11 meters) or a "50 OHM dummy load" on the output of that CB, hate to fry the finals because of no antenna?
That's the first thing I'd be checking.
1987 KLR 650
'00 Voyager XII
'00 Voyager XII
- suzib6sw
- Tourer
Re: CB
Hmm.. thre isnt anything in the passenger bag that will cause no audio from the CB.. They are only there for the hand controls and are paralelled up with the handlebar ones..
I would be looking at the brown collared cable from the back of the radio to the CB initially, behind the headlight. Pull the plug and socket apart and re-connect and wiggle while talking .. All assuming you have the antenna connected.. The original voyager one has a black coil half way up on the left side of the bike..
the Final in the rig is fairly well protected.. I have had only one where it has blown but that was due to a short in the antenna wire. Clarion made a pretty bullet proof rig here..
73's..
Pete.. (De K4/G6IZS) :-)
73's..
Pete
1986 Voyager XII
1986 Voyager XII
- mountainman
Re: CB
Thanks Pete, I will be checking on this. Hoping tonight.
- mountainman
Re: CB
The test was a success. Cb worked okay, we are not sure what fixed it, but it made my day!
Thanks all for the help and suggestions.
Pete, I have a question for you. What is the Auto Mute control for on the radio left side with the volume switch?
My book says-- Auto Mute (optional)
- Bruce in OK
'06 Vespa GTS 250
'02 Honda Elite 80
Re: CB
IIRC, the auto mute will turn the volume down on the radio or cb when the intercom is in use. I could be wrong. If I am, someone else will correct me.
Bruce in OK
- Neal
- Tourer
Re: CB
That mutes the 'background' music when you talk. Turning the knob increases and decreases the level where it mutes.
- mountainman
Re: CB
Thanks Guys!
