Partdiscounter Experience
glvnthedream
Has liked: 46 times
Been liked: 14 times
Post by glvnthedream »
I am searching for Brake discs for my 2002 Voyager and found https://partdiscounter.com/ with incredible prices for both front and back discs. Has anyone used this site in the past? If so, what was your experience? All my discs are at the minimum service limits and according to my cart I can get all 3 for &150 US Dollars.
On another note, has anyone found aftermarket brake calipers that can be used?
Thanks in advance
Regards
Greg
King George VA
Van Voyager
Has liked: 52 times
Been liked: 44 times
Re: Partdiscounter Experience
Post by Van Voyager »
Following ....
glvnthedream (Tue Oct 31, 2023 6:11 pm)
Has liked: 506 times
I get EBC brakes from Amazon, organics are around $90 for all three calipers. Sintered metallics are just a little bit higher, maybe ten bucks, I didn't look.
glvnthedream (Wed Nov 01, 2023 12:19 pm)
Has liked: 242 times
Been liked: 631 times
I bought brakes and lines from Don. Work swell. https://www.amervoyassoc.org/forum/memb ... file&u=239
Has liked: 95 times
Been liked: 155 times
GrandpaDenny wrote: Wed Nov 01, 2023 5:12 am I get EBC brakes from Amazon, organics are around $90 for all three calipers. Sintered metallics are just a little bit higher, maybe ten bucks, I didn't look.
Denny, I beleive he is talking about the rotors (disc's), not the brake pads.
Nails (Wed Nov 01, 2023 1:37 pm) • GrandpaDenny (Thu Nov 02, 2023 12:13 pm)
Has liked: 95 times
glvnthedream wrote: Tue Oct 31, 2023 9:22 am I am searching for Brake discs for my 2002 Voyager and found https://partdiscounter.com/ with incredible prices for both front and back discs. Has anyone used this site in the past? If so, what was your experience? All my discs are at the minimum service limits and according to my cart I can get all 3 for &150 US Dollars.
Thanks in advance
Regards
Greg
King George VA
Greg, I know from my own experience when I was searching for a rear rotor/disc they get a bit pricy depending on the source. I would say $40 for each front and $70 for the rear isn't bad at all. Thanks for the tip!
As for you question about aftermarket calipers, I'm pretty sure I've read somewhere on here that someone swapped out from one bike to another but not sure about aftermarket units. I'm sure someone makes one that fits. Keep us posted on your search/findings!
glvnthedream (Wed Nov 01, 2023 12:22 pm)
glvnthedream
Has liked: 46 times
Thanks. I have no problems finding pads, I am looking for NEW calipers and the discs (rotors). The prices I found on the partsdiscounter site are incredible compared to $100+ each which is what I am finding the norm.
glvnthedream
Has liked: 46 times
Thanks, Scott.
Yep, I am going to jump on the deal and will report my results r/discs. I was assured by the support on the site that they are exact fit. I will be continuing my search for the calipers
Cheers
Scott-(Altoona, PA) wrote: Wed Nov 01, 2023 9:45 am
Thanks in advance
Regards
Greg
King George VA
glvnthedream
Has liked: 46 times
I pulled the trigger on the discs. Partzilla has the REAR and FRONT Discs listed for $416.00 EACH.
Scott-(Altoona, PA) wrote: Wed Nov 01, 2023 9:39 am
Oh you are absolutely right. $150 for NEW discs, all three of them, is an astounding deal. One thing I wonder if at that price are they iron or stainless steel? OEM discs are stainless steel.
glvnthedream
Has liked: 46 times
Confirmed with support that they are Stainless Steel.
Have to give them Kudos for support too, along with the prices. They have been very responsive. Wish they had more XII Parts available.
GrandpaDenny wrote: Thu Nov 02, 2023 12:12 pm
These users liked glvnthedream's post:
Scott-(Altoona, PA) (Fri Nov 03, 2023 7:52 am) • cushman eagle (Fri Nov 03, 2023 7:10 pm)
glvnthedream wrote: Thu Nov 02, 2023 9:24 pm Confirmed with support that they are Stainless Steel.
Cool. Let us know how they work out!
glvnthedream (Fri Nov 03, 2023 10:15 am) • Scott-(Altoona, PA) (Fri Nov 03, 2023 1:35 pm)
glvnthedream
Has liked: 46 times
UPDATE: Posting just to give kudos to the website again. Submitted my order on November 1st. Today, November 4th they have arrived. I am in Virginia.
Stew (Sat Nov 04, 2023 2:26 pm) • cushman eagle (Sat Nov 04, 2023 7:09 pm)
They look raw to me, do they need to be cut? Never having seen brand-new rotors, I could easily be wrong, though.
glvnthedream
Has liked: 46 times
They are indeed Raw. Are there preps needed before installing and riding with them? Thanks in advance
GrandpaDenny wrote: Sat Nov 04, 2023 7:28 pm They look raw to me, do they need to be cut? Never having seen brand-new rotors, I could easily be wrong, though.
Van Voyager
Has liked: 52 times
glvnthedream wrote: Sun Nov 05, 2023 10:07 am They are indeed Raw. Are there preps needed before installing and riding with them? Thanks in advance
Clean with a high flash point solvent and sent it.
glvnthedream
Has liked: 46 times
So clean well with brake cleaner and should be good??
Van Voyager wrote: Sun Nov 05, 2023 1:18 pm
Van Voyager
Has liked: 52 times
glvnthedream wrote: Sun Nov 05, 2023 2:56 pm So clean well with brake cleaner and should be good??
That's what I'd use.
Been liked: 108 times
All brands look like that new. My EBC’s looked like that before I chromed them and have worked good for several years.
glvnthedream
Has liked: 46 times
Chromed them? Explain will you please.
VoyKimmer wrote: Sun Nov 05, 2023 9:41 pm All brands look like that new. My EBC’s looked like that before I chromed them and have worked good for several years.
