moving pass seat back
89 yamaha venture royale - Has liked: 25 times
- Been liked: 59 times
Re: moving pass seat back
Odds are good there's a heli-coil kit for that particular thread size, however that would require removing the oil pan, and some drilling/tapping skills.
- Been liked: 238 times
The thread sealant which cannot be repositioned, will seal it until the next oil change. Once you remove it, it will need to be resealed.
Only downside I can see is that you need to let it cure before you add the fresh oil to the crankcase. For me, that would be a minor inconvenience, but I could live with it, as I am a seasonal rider, and I put low mileage on, typically riding weekends only. Cheers!
- Current bike(s): Sniper Yamaha
Since you're a seasonal rider it might work for your needs until the next oil change avoids a bigger job. Just be sure to let it fully cure as suggested before refilling. Another option could be to have a shop do the helicoil if you're not comfortable with drilling and tapping. Better to pay a mechanic than risk messing up the threads further.
- Has liked: 71 times
So far so good with the Piggyback OS drain plug. Keeping fingers crossed for now, No leaks and all is working out. Appreciate the input..bonvoyagelaine wrote: ↑Thu Jul 11, 2024 7:04 am Since you're a seasonal rider it might work for your needs until the next oil change avoids a bigger job. Just be sure to let it fully cure as suggested before refilling. Another option could be to have a shop do the helicoil if you're not comfortable with drilling and tapping. Better to pay a mechanic than risk messing up the threads further.
