Found a cool spark plug wire source
Heavy Armor
Has liked: 10 times
Been liked: 26 times
Post by Heavy Armor »
Just thought I'd post this here, in case others were shopping. As far as I can tell, the DIY 7mm stuff should work. They have a ton of colors, if that's your thing. ;-) I kinda like the vintage stuff.
Ton's Performance on Ebay:
https://www.ebay.com/sch/i.html?_dkr=1& ... 1&_nkw=7mm
If anyone sees a reason these wouldn't work, chime in.
These users liked Heavy Armor's post:
triton28 (Fri Jun 28, 2024 12:05 pm) • Nails (Fri Jun 28, 2024 3:12 pm) • 4redjf (Tue Jul 16, 2024 12:12 am)
Rating: 33.33%
Has liked: 114 times
Been liked: 289 times
Re: Found a cool spark plug wire source
That 7mm metal braid core is the correct wire for our Voyager XIIs.
Has liked: 234 times
Been liked: 621 times
Having flexible wires sure simplified some maintenance like pulling coils.
4redjf
Has liked: 71 times
Post by 4redjf »
Heavy Armor wrote: Fri Jun 28, 2024 11:32 am Just thought I'd post this here, in case others were shopping. As far as I can tell, the DIY 7mm stuff should work. They have a ton of colors, if that's your thing. ;-) I kinda like the vintage stuff.
I may be replacing my wiring in the future. What would be a good rounded total length and then some for mistakes, that i would need? Also, the metal ends and the boots.
Heavy Armor
Has liked: 10 times
4redjf wrote: Tue Jul 16, 2024 12:15 am I may be replacing my wiring in the future. What would be a good rounded total length and then some for mistakes, that i would need? Also, the metal ends and the boots.
I got 7' just to be safe, and had almost exactly 1' left over. I added an extra 2" or so to each length so I'd have extra to trim later on, and so it wouldn't pull quite so tight when I was taking the plugs loose.
4redjf (Thu Aug 01, 2024 11:21 am)
Heavy Armor wrote: Wed Jul 31, 2024 12:32 am I got 7' just to be safe, and had almost exactly 1' left over.
I also came to exactly 6', after buying 8' (it was cheap).
4redjf
Has liked: 71 times
Post by 4redjf »
Thanks for the details. Been working on house flooring and had to put the bike aside for awhile.
Hope to get back on motorcycle soon.
4redjf
Has liked: 71 times
Post by 4redjf »
Nails wrote: Wed Jul 31, 2024 2:14 am
I'm sure to buy at least 8ft. By the way, what type of tools did you use to strip and crimp the ends onto the wires? I've got electrical wire crimping pliers. Did you solder or anything else other than crimp? When the time comes i always like to have everything on hand before starting the job.
4redjf
Has liked: 71 times
Post by 4redjf »
Forgot to ask, what boots, angled or straight, and metal ends did you use on the wires and where did you get them?
4redjf wrote: Thu Aug 01, 2024 11:30 am what type of tools did you use to strip and crimp the ends onto the wires? I've got electrical wire crimping pliers.
I reused stock boots. IIRC don't need crimping or any tool.
4redjf (Thu Aug 01, 2024 7:02 pm)
4redjf
Has liked: 71 times
Post by 4redjf »
Nails wrote: Thu Aug 01, 2024 6:05 pm
Don't know about the boots till i start the project but i do know the wires are very stiff.
What is iirc?
Has liked: 491 times
Been liked: 444 times
4redjf wrote: Thu Aug 01, 2024 7:03 pm
What is iirc?
If I Recall Correctly
There is no crimp on the wires, they stab into the boots. The boots have a prong that inserts into the wires, just by pushing the wires in firmly. So for future reference, and easy fix in many cases for bad wire connections is to pull the wire out of the boot, trim a bit off the end, and cram it back into the boot. You don't even have to pull the boot to do it.
And many, many hard-to-figure-out misfires have turned out to be just that, not pushed into the boots far enough, or gotten rotten on the end and needing trimming. Been there, done that.
triton28 (Fri Aug 02, 2024 9:10 am) • 4redjf (Sun Aug 04, 2024 9:05 pm)
2008 Ford CVPI
SJ Retreads, PGR, WWR
Heavy Armor
Has liked: 10 times
4redjf wrote: Thu Aug 01, 2024 11:37 am Forgot to ask, what boots, angled or straight, and metal ends did you use on the wires and where did you get them?
https://www.happy-trail.com/spark-plug- ... -8022.html
All the actual NGK ones I found online shipped from Europe, making them more cost prohibitive. These are Fire Power brand... they seem alright, though the rubber boots on top aren't as nice as the OEM.
The caps have a screw inside, so you slip the cable into the end and twist until it stops.
4redjf (Sun Aug 04, 2024 9:06 pm)
