Fork tube pitting
MonsterMash479
1
Current bike(s): 1996 Kawasaki voyager xii
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
Fork tube pitting
Post by MonsterMash479 »
Previous owner said he had the fork seals redone before i bought the bike, after riding about 500 miles they started leaking like a sieve, took them apart and found this pretty bad(to me) pitting on the fork tube, and clear evidence where the guy tried to scotchbrite it away. Do i need new fork tubes?
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
Re: Fork tube pitting
And can anyone tell me if these are progressive springs or not? They look awfully short
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
Update#3 this happened? Has anyone seen this happen to the spring collar or whatever before?
Has liked: 242 times
Been liked: 631 times
MonsterMash479 wrote: Tue Sep 24, 2024 11:56 amThey look awfully short
Stock suspension has a large spacer that you don't use with Progressives.
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
Okay so im assuming thats what split open and the spring jammed inside of in the photo looking down the tube.
biguns
1
Current bike(s): 2000 Voyager,1980 Goldwing
Has liked: 9 times
Post by biguns »
If you want to ride now and take your time looking for forks you can sand your forks across (not up and down)Cut it in long strips and sand evenly around the tube using 1K wet and dry maybe 800 depending o results then finish off with 1200 or 1500 and this should clean off any sharp edges and light pitting then with what's left use JB weld slow drying to fill in pits pushing it into the pits clean so you don't have to sand much let set up 24 hrs and then sand it flush.
This is not a high stress function for JB so it should hold indefinitely or at least give you time to shop around for a nice pair.
I did this on an old Honda I couldn't find a decent set ended up looking good and drove it thousands of miles leak free.
Progressive springs gapping is spaced bigger along the length so an even gapped spring along its full length is not progressive.
good luck with your project.
And another thing if you try this get a needle and scratch out the inside of the pit as well as possible.
These users liked biguns's post:
Nails (Mon Oct 07, 2024 12:52 pm) • MonsterMash479 (Thu Oct 10, 2024 8:22 pm)
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
Thank you thats basically what i ended up doing. Still getting the other half of my project done so well see how it holds up once i ride it again :pray:
These users liked MonsterMash479's post:
biguns (Wed Oct 16, 2024 5:54 am)
